Discussion topic: Mini box not connected
Message posted on 23 Aug 2024 08:18 PM
Sky mini box in bedroom is not working. Everything is working fine downstairs but not upstairs it's saying there's no Internet connection or sky Q box connection
Message posted on 23 Aug 2024 08:24 PM
Re: Mini box not connected
Hi @Mikeeeh
Reboot the mini as above.
