Discussion topic: Mini box not been found
This message was authored by: Joy631
Just got a mini box and also new tv.  Gone through everything but with the remote set up etc it keeps saying it can not find the box
Re: Mini box not been found
Hi @Joy631   It is not clear, what is saying it cannot find what box.
Avatar for Joy631
Just saying not connected.
Hi @Joy631
Reboot the mini as above.
