Discussion topic: Mini box no apps
This message was authored by: MCCrystal
Mini box no apps
No apps after sky engineer fitted a sky router booster
Re: Mini box no apps
Hi @MCCrystal
Reboot the mini as above.
On Sky Broadband if the booster is the nearest Sky device you can use that for WPS instead on the main box.if the Router is nearer to the mini than the main box or booster then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button.
