3
This discussion topic has been answered Discussion topic: Edwards
This message was authored by: David284
Edwards
Hello hi,
(removed)
I've got an issue with my mini box that's Just installed I have a problem with no menu on the screen wondering could you get me a Engineer out please? That would be grateful thank you.
Moderator note: Removed personal/identifiable details
Re: Sky mini box not working
@David284 wrote:
What's happening? It's turned on with the on light showing it goes to the menu saying hello and then it goes to the homepage then it's a black screen. No Sky menu whatsoever.
Hi @David284
If the mini is showing a Green led
First make sure that the TV is switched on and is switched to the HDMI input to which the mini box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the mini box remote control.
This will change the mini box to standard resolution which will work for all TV’s.
Re: Edwards
@David284
Your post has been removed as you've included your name and full address on a public forum. It will reappear once edited by staff.
This is a customer helps customer forum so you’re not contacting Sky Customer Services by posting on here and can't arrange an engineer here.
Have you rebooted the boxes?
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for David284
Hi @David284
Press
Home 1 0 8 0 Home
