Discussion topic: Mini box never connecting
Message posted on 30 Dec 2024 05:02 PM
The mini box is never connecting, and giving various codes - latest one is MR002. I have rebooted and its connects but then use it the following day and I get the same message.
Message posted on 30 Dec 2024 06:27 PM
Re: Mini box never connecting
Reboot the mini as above.
