Discussion topic: Mini box issue
This message was authored by: norman1lucas
Mini box issue
My sky q mini box has suddenly come up with ' no connection to sky q box' everything is plugged in, ive rebooted mini box and main box , router etc. Still not working. Any ideas please
Re: Mini box issue
Hi @norman1lucas
Try all the following again.
Reboot the mini as above.
