Discussion topic: Mini box is freezing
This message was authored by: GerryT1
Hi I have one mini box and recently this has started freezing . I have no issues with the main box Have tried multiple reboots to no avail
Re: Mini box is freezing
Hi @GerryT1
Try a Network Reset on the mini.
This message was authored by: Lex
Sqy Q not starting properly. After pressing Home button Q  just switches off
