Discussion topic: Mini box has stopped working
Message posted on 16 Mar 2024 01:43 PM
Sky mini box has stopped working.
it just keeps freezing.
Pretty sure nothing wrong with WiFi signal and sky working fine in the main room.
Message posted on 16 Mar 2024 01:48 PM
Re: Mini box has stopped working
Hi @Mia+l
Try completely resetting it.
Reboot the mini as above.
