Discussion topic: Mini box frozen displaying error MR102
This message was authored by: Annlynn2
Mini box keeps saying no signal and i have tried to reboot  now screen frozen
Re: Mini box frozen displaying error MR102
@Annlynn2 I have answered both your posts with the following
Have you tried rebooting your main Q box ie
then reboot your mini
Hi @Annlynn2
I know you have already tried reboots but try the following
First reboot the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
