Discussion topic: Mini box frozen displaying error MR102
Message posted on 17 Mar 2024 04:38 PM
Mini box keeps saying no signal and i have tried to reboot now screen frozen
Message posted on 17 Mar 2024 04:50 PM
Re: Mini box frozen displaying error MR102
@Annlynn2 I have answered both your posts with the following
Have you tried rebooting your main Q box ie
then reboot your mini
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 17 Mar 2024 05:31 PM
Hi @Annlynn2
I know you have already tried reboots but try the following
First reboot the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
