Discussion topic: Mini box frequently disconnecting
This message was authored by: Fatman247
The sky q mini box keeps disconnecting from the main box, but it says it is connected on the main box.
im having to restart the sky q mini box about 3/5 times a day as this is happening regularly.
i have also reset the broadband but the same thing keeps happening.
then yesterday, the remote also started to lose connection and I now need to reset the sky q mini remote  to the sky q mini box - I have had to do this twice.
is this something that can be fixed?
Re: Mini box frequently disconnecting
@Fatman247 If you have not done so reboot your main Q box ie
then
reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Rixysky
if you are having a network issue and it's causing this try to obtain a new IP address. In the settings menu go to broadband if you have an x press reconnect and assuming this doesn't work go to contninue. When system reboots it should take you through the steps to give u a new IP address then your box might work - 🤞if not then it's engineer time.
Avatar for Fatman247
Thanks - have done that many times.
