Discussion topic: Mini box fast forward and rewind issues
Message posted on 22 Sep 2024 08:03 PM
one of our mini boxes is faulty glitching when forwarding and rewinding. Once it's doing either it won't stop when we press play, just carries on and stops randomly.
do I need a new box?
batteries in the remote are brand new and I've checked their power. All good.
Message posted on 22 Sep 2024 08:42 PM
Re: Mini box fast forward and rewind issues
@Silay80 Have you tried rebooting your main Q box ie
then
reboot yoiur mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 22 Sep 2024 08:54 PM
Yes I've done this a few times over the last few weeks, makes no difference unfortunately. 👍🏻
Thanks for replying! 👍🏻
Message posted on 22 Sep 2024 09:42 PM
Hi @Silay80
First
Try a Reset Settings in the main Q box hidden menu.
Once the main Q box is back up and running and you have re paired it's remote if you still have the same issue with the mini then carry out a reset settings in the mini hidden menu.
You will have to re pair the mini remote after the reset
