Discussion topic: Mini box does not work when main box is on
This message was authored by: CCblue
Hi,
My mini box works fine so long as the main Sky Q box is not in use.  As soon as the main box is switched on I can no longer watch anything on the mini box!
Re: Mini box does not work when main box is on
@CCblue wrote:
Hi,
Hi @CCblue
Try a Network reset on the Mini.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Avatar for CCblue
@oldfella  thanks but I just end up in the same situation. The mini box works perfectly until the main box is switched on... then it says 'you have network issues' and I can't access any tv channels.  I've not seen this issue anywhere else so I think it's time to cancel the mini box subscription...
Hi @CCblue
Try a Reset Settings in the main Q box hidden menu.
Avatar for CCblue
Hi @oldfella thanks once again, but even after that I just end up in exactly the same situation...
This message was authored by: Lisa-P1987
Hi there @CCblue , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Lisa - Sky Tech Team Expert
This message was authored by: Addie15
Update-We are closing this session now due to no further response within 48 hours. If you still need help, please let us know so we can re-escalate this for you. Thanks.
