Discussion topic: Mini box disconnects
This message was authored by: toptinker
Hi the mini box appears to disconnect overnight and need to go through reconnection every morning. I check the settings on the mini box most of the time it says there is a problem with the network . I go to network settings and it has 2 ticks saying everything is ok ?
Re: Mini box disconnects
You can try changing the eco mode on the main box so it doesn't completely go to sleep.
Hi @toptinker
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Avatar for toptinker
Level 2 icon
Thanks some info . The sky router is next to the main box . The mini box is hard wired to main box so wifi settings are off. If I was to connect via wifi this would. It be a signal issue as I have the sky booster next to the mini box
Don't know why you have booster @toptinker  if the Mini is hard wired.
If you have the Sky Max fibre router this can cause issues with Sky Q.
Normal scenario with your setup and location would be all wired to Router.
Level 2 icon
THANKS i have the booster to gain a strong wifi signal outside to the shed to view online content
Your mini can act as a wifi hotspot.
Level 2 icon
hi a update on this. it seems to still be the same and the mini goes through its set up every morning, 1 thing to note is that it does not do this the later in the morning after 8ish am usually does the set up at 6ish am approx so any more tips would be great ???
@toptinker as has been said before go into settings and change fro eco mode to none and do this on both your main box and mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Level 2 icon
ok thanks. i am sure i have done this, but i will check
Level 2 icon
ok checked the main box is off but the mini box that i am having this prob was eco. so changed to off. do we think this is was the issue. what i dont understand is wht the issue first thing in the morning but not slightly later on ?
@toptinker The issue is that in eco mode they go into a deep sleep between 2.30 and 5.45 which causes the boxes to take a long time to waken up going through the whole start up process rather than just coming out of standby
