Discussion topic: Mini box dead
Message posted on 20 Sep 2025 03:17 AM
Mini box dead
Mini has orange light but did not turn on, unplugged and when plugged back in it goes orange for 1 second then goes off, no
lights at all.
when press reset orange light come back but still doesnt come back on.
other mini box works ok
Message posted on 20 Sep 2025 03:17 PM
Re: Mini box dead
lights at all.
@Thomass4 does it come on if you press the orange light as that is the manual on/off button
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 22 Sep 2025 04:35 AM
Re: Mini box dead
No, nothing happens whatsoever, if i power down then plug back in the orange lights appears for 2 seconds then goes off, no lights at all, when i press reset on the back the orange lights appears comes back but nothing happens
Message posted on 22 Sep 2025 07:22 AM
Re: Mini box dead
And when you physically press that orange light button, nothing happens then?
Message posted on 22 Sep 2025 11:05 PM
Re: Mini box dead
Nothing happens when i physically press the orange lights appears button
Message posted on 23 Sep 2025 07:50 AM
Re: Mini box dead
Use rhe box teoubleshooter on sky.com
it ends with a replacement being sent out.
