Discussion topic: Mini box connectivity
This message was authored by: Geoff1131
After Sky Q mini box in bedroom kept dropping connectivity I reset internet connection on main box but now mini box shows Error MR001 saying Unsuccessful Connection. It says to set connection on main box. Help appreciated!
Re: Mini box connectivity
@Geoff1131 Have you tried rebooting your router then when that is up and running
reboot your main Q box ie
then finally rebooting your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Winkle
I've tried the rebooting the Q box then the mini box, still not working. Called Sky and they said they couldn't help or provide an update. Fuming
Hi
@Geoff1131
@Winkle
Try a Network Reset on the mini.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Avatar for Geoff1131
Thanks for your replies. Problem now resolved with help from the Sky support phone line.
This message was authored by: Just0815
Hi, my name is Julie, I am writing this as my husband can't help as he had a stroke over 3 years ago and so I have to sort out any problems.  I have been having same or similar problems with my sky q, at the moment tv screen says "It looks like you do not have internet connection right now"  Go to settings and check your network connection status to reset.  There were ticks in both boxes, (connection to sky q box and network connection) then network onnection kept losing connection, went to network connection many times and reset, this time on screen "there seems to be a problem with your broadband" before pressing reset, it reset itself and then disonnnected again and again.  I have followed all the instrustions on the sky website. I've tried the rebooting the Q box then the mini box, still having problems. I have tried resetting network settings Home - Settings - Setup - Network.)
Highlight Status and then select Reset on the right hand side. I followed instructions to WPS with main Q box. I then pressed the WPS button on the main Q box.
This has been going on for almost a week now and I'm really struggling🥲
Unfortunately this is how bad the Q's networking is. I use powerline adapters between the mini and Q and then they use ethernet and seem much happier.
are you on sky broadband or another provider? If sky do you have the old black router or a new white one?
