Discussion topic: Mini box 2 keeps loosing signal
This message was authored by: YRich
My Dky Q is connected to internet no problems, mini box 1 is fine but Mini box 2 keeps loosing signal and sound keeps disappearing and then coming back! When I check network connection it is ok but sometimes it is lost
Re: Mini box 2 keeps loosing signal
@YRich Have you tried rebooting your main Q box ie
then
reboot each mini box or if the first mini is still ok the reboot the second one
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
