Discussion topic: Mini Box
Message posted on 04 Apr 2024 11:01 AM
Mini Box
Mini Box has stopped working.
Message posted on 04 Apr 2024 11:13 AM
Re: Mini Box
That's not a lot for us to go on. You aren’t contacting Sky Customer Services by posting on here. This is a customer to customer forum where we try to help each other.
Message posted on 04 Apr 2024 11:19 AM
Re: Mini Box
If it's not turning on or is stuck on standby, Try a power reboot or the recovery procedure as described here;
Message posted on 04 Apr 2024 11:28 AM
Re: Mini Box
Hi
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the Q box on
Try completely resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
