Discussion topic: Mini Box
Mini Box
Mini Box has stopped working.
Re: Mini Box
That's not a lot for us to go on. You aren’t contacting Sky Customer Services by posting on here. This is a customer to customer forum where we try to help each other.
Re: Mini Box
If it's not turning on or is stuck on standby, Try a power reboot or the recovery procedure as described here;
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-q-equipment/sky-q-box-wont-turn-on...
Re: Mini Box
Hi
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the Q box on
Try completely resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
