Discussion topic: Mini Box stuck on this page and won't accept commands from Sky Remots
Message posted on 18 Jul 2025 05:05 PM
Helping my even older neighbour - today she had new fibre cables and set up installed. All good - tv connexted, phone, laptop etc all good.
She has mini box in bedroom. At set up, came across this screen. Cannot get any further - screen frozen. Commands not accepted from the Sky Remote.
Any ideas?
Message posted on 18 Jul 2025 05:07 PM
Re: Mini Box stuck on this page and won't accept commands from Sky Remots
Any ideas?
hi @Robert01506
This message seems to have caused a bit of a quirk so try this:
Press & hold 4 & 6 on the remote to set to Infrared only (so must have line of sight of the box)
Hopefully you can then dismiss the message
Then try re-pairing in bluetooth mode with the box by pressing & holding 1 & 3 together
If this does not work try a full remote reset by pressing & holdng 7 & 9 until the red led above the SKY logo button flashes 4 times
Then try the 1&3 to re-pair & pair with the TV
Message posted on 18 Jul 2025 05:12 PM
I shall try when next round at my neighbour's house.
I perhaps should have said that when frozen at this screen, the remote can still control volume and up volume down but nothing else.
R
Message posted on 18 Jul 2025 05:22 PM
R
hi @Robert01506
Yes the volume control is not affected by this
Hopefully it will work , hopefully the first steps will work
If you do have to do have to do a reset you will need to follow the steps closely to ensure the TV volume continues to work (it won't immediately after the reset - the pairing back with the TV is part of the process)
