Discussion topic: Mini Box saying no prescription
This message was authored by: markgfuyuyvuv
Hi my Sky Q mini box is no showing any programmes across the board or any recordings saying I have no prescription to this channel.
My main Sky box is working fine and I'm having no internet connection issues at all.
I have rebooted both boxes several times now without success.
Re: Mini Box saying no prescription
Hi @markgfuyuyvuv
Assume the mini came from Sky and you have the monthly Sky Q Multiscreen subscription?
Try a Network Reset on the mini.
Avatar for markgfuyuyvuv
Thank you for the advice. I have tried it and it still didn't work. My mini box did come from Sky and I do have the subscription.
I have the box for two years with no issues no all of a sudden this.
Any other suggestion?
Hi @markgfuyuyvuv
Try a Reset Settings in the main Q box hidden menu.
Once the Q box is completely back up and running reboot the
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
