Discussion topic: Mini Box not working
This message was authored by: MarieJones
My mini  box is not workin, after going through the settings it says I've not got the subscription for this, which is rubbis!!  I have not changed any of my details and it was working fine yesterday 22/12/24.
Re: Mini Box not working
Try first  rebooting your main Sky Q box.
Leaving off power for 30 mins.
When main box is  back up, leave running for about five minutes, repower the mini box.
Hi @MarieJones
Try a Reset Settings in the Main Q box hidden menu.
