Discussion topic: Mini Box not connecting Keeps going off saying no network connection
This message was authored by Philip25 This message was authored by: Philip25
My Sky Q mini box will not connect.
The main Sky Q box has been rebooted.
mini box starts.   Then loses connection again.  It is now failing to connect every day.
philip25
Re: Mini Box not connecting Keeps going off saying no network connection
philip25
Hi @Philip25
Reboot the mini as above.
