Discussion topic: Min
Message posted on 25 Jul 2024 09:04 PM
Min
Mysky mini box is showing a technical fault, but all Internet access is
Message posted on 25 Jul 2024 10:08 PM
Re: Min
Hi @MB31
Reboot the mini as above.
Message posted on 27 Jul 2024 12:54 AM
Re: Min
Hi all I've tried all of that, but it still doesn't work
Message posted on 27 Jul 2024 10:03 AM
Re: Min
Hi @MB31
See if a Reset Settings on the main Q box.
Settings is in the Q box hidden menu.
