Discussion topic: Message on screen
This message was authored by: Bevie77
Message on screen
I keep getting a message saying - you will soon lose your sky channels to keep viewing go to sky.com/myaccount, I go there and it doesn't tell me anything but the message comes up every day through the day. Also my sky is being very slow in the menu and changing channels etc
Re: Message on screen
Hi @Bevie77
This message was authored by: Maniatore2006
Your Viewing Card needs an Updated avery 2 Months to be extended, when you have your SKY Q in Deep Standby or Off your card not get the Updates.
The Card Updates comes normaly, Two times a day.. but you can also Renew your Card manually. Under Settings, System Info, Viewing card Number and Setup, and that Trigger a Callback.
That is just a Guess fom my side, i am also new in the SKY Q Life... but that with the card is a Fakt.
I guess the SKY Q is Smart enough to Check the Runtime of the Card.
Or your Contract is just Running out.. in that Case, call SKY.  😎😁
SKY Q, With Entertainment SD and Sky Sports HD.
