Discussion topic: Match Your Viewing Card Message
This message was authored by: Tricky73
I have a SKY Q package at my caravan in Anglesey- middle of nowhere, no broadband so I have a dish. I currently do not have any access to any of the Sky channels in my package and have a constant messaage that my card needs matching. Have followed all the instructions but always come beck to 'make sure you broadband connection etc." I DO NOT HAVE A BROADBAND CONNECTION which seems to be the answer whenever anything goes wrong! Anyone have any experience with this- seems like you're a 2nd class customer if you just have a dish- pay for NETFLIX- asks me to check my broadband connection, Movies? Check broadband connection. Apps, you need broadband connection. Main menu? You need an
upgrade!
Thanks a lot.
Re: Match Your Viewing Card Message
upgrade!
Thanks a lot.
Hi @Tricky73 I assume that your SKY Q subscription is registered to your caravan, and that the the SKYQ equipment was installed by a SKY engineer?
The reason I ask is that a SKYQ TV subscription will need a broadband connection to access SKYQ apps and to download catch up content,
The broadband connection will also let the SKYQ box verify your viewing card!
This message was authored by: simon194
@Quoman7 wrote:
upgrade!
Thanks a lot.
If the viewing card has got unpaired, without a broaadband conection the only way to re-pair it will be to phone Sky and get them to manually re-pair the card.
_____________________________________________________
