Discussion topic: No satellite signal
This message was authored by: Miche19
No satellite signal
I was cleaning, wiped over the router and both the TV signal froze & went blank. Have tried to reset , not working. Have gone to Settings - Status ... it shows satellite signal with a x the rest have a tick
Re: No satellite signal
Unless you've disturbed the satellite inputs on the box then it's unlikely cleaning in itself would cause the issue with a satellite signal.
I would remove the 2 inputs, (they screw in/out) ensure they are sound (not wires loose etc.), reinsert them and power back up.
If that fails then you might need to call Sky to investigate the dish/cabling.
