Discussion topic: Main box not linking to TV but mini boxes working
Message posted on 30 Apr 2026 11:24 AM
My main sky box is not linking to my TV. The TV itself is working as are the mini boxes. I've tried turning off and on. Any help would be appreciated. Thank you.
Message posted on 30 Apr 2026 11:34 AM
Re: Main box not linking to TV but mini boxes working
Hi @Jane74
Did you reboot as follows :-
If the Q box is not responding to the remote With the Q box on with green led try completly resetting your Bluetooth remote.
Message posted on 30 Apr 2026 11:47 AM
Thank you very much for your help. I have done this. The Sky box responds to the remote, it's just the TV doesn't respond. So I have a green light on the Sky box but it says no signal on the TV. I've checked the connnections too.
Message posted on 30 Apr 2026 12:14 PM
Hi @Jane74
First make sure that the Television is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
Message posted on 30 Apr 2026 12:44 PM
Thank you again. I have done all of this but the message on the screen is still No Signal so nothing happens when I press 1080 on the sky remote. So sorry to take your time up.
Message posted on 30 Apr 2026 07:27 PM
Hi @Jane74
Did you press Home 1 0 8 0 Home (ie not just 1 0 8 0)?
If you still get no signal (and you are sure the correct input has been selected on the television) then maybe there is an issue either with HDMI cable or its connection. Try another cable if you have one
Message posted on 01 May 2026 01:44 PM
Still no joy I'm afraid, but thank you so much for trying. I think it maybe needs a new cable. Thank you again.
Message posted on 01 May 2026 02:38 PM
@Jane74 Swap the cable with one from your Mini Box.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 01 May 2026 03:41 PM
Will try. Thanks very much 👍
