Discussion topic: Main box needs rebooting multiple times per day
This message was authored by: pjn789
My main box seems to have started to need a regular reboot. It stops playing anything and the only solution is a full reboot. WiFi connectivity also seems to have gone really flaky with the mini boxes losing connection about every 10 mins. Nothing has changed and they were previously absolutely fine.
Re: Main box needs rebooting multiple times per day
Hi @pjn789
Have you tried a Reset Settings in the Q box hidden menu.
Avatar for pjn789
Thanks for this, have given it a try but made no difference, still had to power off at the mains 4 times since I did this reset.
