4
This discussion topic has been answered Discussion topic: Copper wire in put channel 1 broke off. How to repair?
This message was authored by: Rara-Avis
Can't see how to remove collar to extend copper wire
This message was authored by: nigea99 Answer
Re: Copper wire in put channel 1 broke off. How to repair?
hi @Rara-Avis
I am not too sure why you are wanting to remove the F-Connector if you are wanting to extend as the best way to extend is to use an F-F connector
F ConnectorsF Connectors
If you do need to remove it probably easiest is to just cut the cable
If making your own extension cable this video may also help:
Fitting an F-Connector
hi @Rara-Avis
Avatar for Rara-Avis
Not wanting to extend. The copper wire bent & broke off when I bent it back. I was reconnecting my Q box after decorating.
@Rara-Avis
As @nigea99 indicated there are multiple videos on YouTube showing how to attach F-connectors to coaxial cable.
If you have crimped F-connectors then you may need to replace these with twist-on hardware: this costs about £1
@Rara-Avis
Note that you could book Sky to resolve the issue: you'd be waiting for an installer and they could legitimately charge you for the job (typically £65)
