Discussion topic: MR104
This message was authored by: Karron1
MR104
This is happening more and more and usually a quick reset gets it going but nothing this time after several attempts, WiFi is fine no different to normal
This message was authored by: Me134
Re: MR104
This is from a Sky Q mini box? Have you tried turning off both boxes for a minute and then letting the main box boot up fully first and then the mini box?
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access with MLO enabled, main Deco hardwired to Max hub
Re: MR104
@Karron1
As suggested above it's always worth starting with a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Also see this link here
https://helpforum.sky.com/t5/Sky-TV/Error-Codes-on-Sky-O-and-Glass/ba-p/4017045
Re: MR104
Hi @Karron1 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, do the same with any Mini boxes?
