Discussion topic: Blue screen on mini box but no message
Message posted on 17 Jul 2026 06:08 PM
Mini box brings up Home Screen but no preview in top corner and when select a channel just have blue screen with channel name detailed bottom left but no picture or sound. Have done the reset, cable check, settings check, system upgrade on both main and mini box. Nothing works.
Message posted on 18 Jul 2026 08:41 AM
Re: Blue screen on mini box but no message
Hi @a_coyle Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, do the same with any Mini boxes?
