Discussion topic: Loud static noise and screen interference
Message posted on 30 Jan 2024 09:07 AM
getting loud static noise and interference through sky Q box which comes through Netflix and Amazon tv also
Message posted on 30 Jan 2024 09:34 AM
Re: Loud static noise and screen interference
hi @Henry3460
Regarding the Loud Static noise - Is it possible your TV/Sound System cannot cope with Dolby Digital ?
Try setting
Home - Settings - Setup - Audio Visual
Digital audio output HDMI
to Normal if not alrady set
Message posted on 06 Feb 2024 04:33 PM - last edited: 06 Feb 2024 04:35 PM
I've had this problem too but I can't figure out if it's the tv or sky Q box...
What tv model do you have? Ours supports Dolby Digital Plus so I don't think that's the issue
