Discussion topic: Lack of internet connection
This message was authored by: Jasper4
Lack of internet connection to my sky q box and the mini sky q box
name Brady Lesley
My internet router is working and we have full WiFi service.
Have tried rebooting Sky Q box and mini box. Have also removed and replaced viewing card
Re: Lack of internet connection
name Brady Lesley
Hi @Jasper4
First step is a Network reset on you main Q box.
