Discussion topic: Loud Sky Q box
This message was authored by: DBancroft
Loud Sky Q box
Every day our sky q box is blowing really loudly and fails to power on. Have to turn it on and off every day now. It generally works for a few hours after reboot
Re: Loud Sky Q box
Hi @DBancroft
Assume your Q box is well ventilated and not stacked with other devices.
Current high ambient temperatures could be causing the Q box to run hot.
  • instead of a reboot try a Reset Settings in the Q box hidden menu.
