Discussion topic: We have changed WiFi provider but our sky Q boxes won’t work now
Message posted on 16 Aug 2024 03:56 PM
We have changed our internet provider but our sky W boxes won't work today
Message posted on 16 Aug 2024 04:16 PM
Re: We have changed WiFi provider but our sky Q boxes won’t work now
On each Sky Q box go to your settings > network and perform a network reset, then follow the prompts.
Message posted on 16 Aug 2024 04:19 PM
Hi @PE4
Try to get your main Q box connected first.
Start with a reset your broadband router.
Wait until the router is completely back and running and then try a Network Reset found in main Q box Home - Settings - Setup - Network.
