Discussion topic: Lost recordings
Message posted on 17 Oct 2023 07:26 PM
Lost recordings
Lost all recordings when box stopped working and had to turn off and restart
Message posted on 17 Oct 2023 08:17 PM
Re: Lost recordings
@Fi5 Have you tried rebooting your main Q box again
failing that
You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
