8
This discussion topic has been answered Discussion topic: Lost connectivity for streaming via Q Box
This message was authored by: Colin+Grant
My Sky Q box cannot connect to the satellite thanks to scaffolding being around the house. It has been there over a week. Up until today we have been able to access, via the Q Box, the apps that use internet streaming rather than the satellite (Netflix and the like). Today however that connectivity is not available. I understand that periodically Sky Q "phones home" and if satellite connectivity is not available it locks the user out.  Is this the way it is and is there a way out of this? Seems a bit heavy handed to me as I am still paying!
Colin
This message was authored by: Laing1 Answer
Re: Lost connectivity for streaming via Q Box
Colin
@Colin+Grant afraid you are correct and apart from getting the dish moved then there is nothing you can do about it unfortunately.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Deedee36
@Colin+Grant  Are you getting any onscreen message??
“Trying to help improve sky glass”
Avatar for Colin+Grant
Level 4 icon
IT says "There is an issue with your streaming device. Restart Netflix and try again". It is the same for Disney etc.
An issue with your streaming device? Have you got sky q or sky glass?
Level 4 icon
I have Sky Q
I would suggest phoning sky if you have tried a power down of you box,it could be as you have said because you box hasn't received a satellite signal.I haven't come across this before but maybe someone else on the forum will be more able to advise
Colin
Level 4 icon
Thank you. Kinda makes Glass seem even more attractive.
@Colin+Grant  Just be aware stream/glass is a different concept to q in reguards to recording ability if that's something you rely on
