Discussion topic: Lost channels
Message posted on 09 Jul 2026 09:55 AM
Lost channels
I have a satellite signal but have lost some channels
Message posted on 09 Jul 2026 09:57 AM
Re: Lost channels
Hi @Janet5808
Have you tried rebooting your Q box?
Message posted on 09 Jul 2026 09:59 AM
Re: Lost channels
Yes I have several times, very frustrating just want to talk to someone get this resolved, thanks for replying to me
Message posted on 09 Jul 2026 10:26 AM
Re: Lost channels
@Janet5808 wrote:Yes I have several times, very frustrating just want to talk to someone get this resolved, thanks for replying to me
Hi @Janet5808 Please see Welcome below for information about this public community forum.
Message posted on 09 Jul 2026 10:39 AM
Re: Lost channels
hi @Janet5808
Do you get a message onscreen when you select the missing channel?
Message posted on 13 Jul 2026 10:21 PM
Re: Lost channels
Thankyou for replying, yes have tried the usual, disconnect, re connect, still same quite a few channels show no signal.
Message posted on 13 Jul 2026 10:24 PM
Re: Lost channels
Yes this channel is currently affected by a problem with your satellite signal
Message posted on 14 Jul 2026 04:56 AM
Re: Lost channels
@Janet5808
”No signal” messages tend to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you have a ”No satellite signal” message, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely either;
▫️a dish misalignment,
▫️a failing LNB (on the arm of the dish),
▫️water getting into the cabling,
▫️it is currently raining very heavily
so check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
If you are connected to a communal dish you need to liaise directly with your building management company or landlord who will have their approved engineers to contact direct.
Additionally:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
