4
This discussion topic has been answered Discussion topic: Loss of channel with re-negotiated contract
This message was authored by: Jason_6
I have just re-negotiated my contract and have just found I am unable to download programmes from sky history. It states I need to press red to upgrade. I am able to view Sky History 'Live' currently. I have removed HD and Ultra HD from my package but the programme was not on Sky History HD. Can anyone advise?
This message was authored by: digglerthelegend Answer
Re: Loss of channel with re-negotiated contract
Have you changed the default download setting from HD to SD?
To change your download preferences, you need to complete this on the main Sky Q box, not a Sky Q mini box:
  1. Press Home on your Sky Q remote and select Settings, then Setup.
  2. Select Preferences, then On Demand default download format, and choose SD, HD or UHD.
If your default download format is unavailable, it’ll download in the next available format. For example, If HD is unavailable, the show will download in SD.
Individual shows
You can download an individual show in a different format without changing your default settings. Just select the show you want to download, select All formats and choose from SD, HD or Ultra HD where available.
________________________________________________
Sky Q 2TB (V3). 2 x Mini. LG G3 65inch. LG S95 QR 9.1.5 Soundbar. Sky Full Fibre Gigafast Broadband.
Individual shows
Avatar for Jason_6
Thank you @digglerthelegend I will try that and let you know. Appreciate your help.
Avatar for Jason_6
@digglerthelegend That has done it! - fantastic ! - thank you for your quick and accurate response. Much appreciate the problem being solved. Have a good week-end!
@Jason_6 Happy to help.  Glad you're all sorted.
