Discussion topic: I replaced my old sky Q mini box and it won’t show appts
Message posted on 13 Jul 2024 04:37 PM
I replaced my old sky Q mini box and it won’t show appts on the new mini Q
Message posted on 13 Jul 2024 04:41 PM - last edited: 13 Jul 2024 04:47 PM
Re: I replaced my old sky Q mini box and it won’t show appts
Hi @Mandy52
First thing to do is a Software Update to make sure the box is on the latest Software.
Home - settings - System info - Highlght Software version and then select Setup and then select Update this box with latest Software.
Any Q box (including minis) may require a manual software update at times.
For example a replacement Q box or mini or any box that is powered off when an update is released.
However bear if mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
All Q boxes and minis should be on the same software version.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
https://www.sky.com/help/articles/updating-sky-box-software
Once all the software us up to date
First reboot the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
