Discussion topic: Location Check Failed
Message posted on 19 Dec 2023 01:05 PM
I am having an issue when trying to download programs on my sky Q box. It keeps giving an error saying 'Failed, location check failed' I have spoken to sky support who have reset the box and sent a replacement, but I am still having the issue with the new box. I have since been told it is an issue with my ISP, but the only service I am having issues with is Sky downloads. from the Sky box (and other devices) I can use iPlayer, ITVX, All4, Netflix and Prime. I can also use Sky Go from my home broardband so the issues is only affecting the sky download service on my Sky Q box.
Is anyone able to help with this?
Message posted on 19 Dec 2023 01:29 PM
Re: Location Check Failed
@Hollab wrote:Is anyone able to help with this?
Normally your ISP in the first instance to ensure the public IP address they have issued you is correctly registered in the UK.
Message posted on 19 Dec 2023 01:46 PM
I have checked with my ISP and a number of IP geolocation sites. including iplocation.net, IPLocation.io and the location checker on other sites like NordVPN and Surfshark who all report my IP as from London UK. as I live in wales I assume that it where the ISP have registered the addresses and should be ok.
Has Sky got an outdated GeoIP list?
Message posted on 19 Dec 2023 01:57 PM
Which ISP are you with?
Message posted on 19 Dec 2023 01:58 PM
Youfibre
Message posted on 13 Mar 2024 08:51 PM
Were you ever able to get this issue resolved? - And if so, how? - I am currently seeing the same problem as well!
