Discussion topic: Can't connect Sky Q to my eir broadband
Message posted on 09 Feb 2024 10:12 AM
I have Sky Q and Eir broadband. Got the message on screen that it looks like I do not have internet connection. So when I try to connect to wi-fi from another broadband provider and put in my internet password it says Unsuccessful connection. Please check your password is correct. It's definitely the correct password I'm putting in. There's no issue with my broadband. I'm connected fine on other devices. It's just Sky tv that I can't connect to.
Message posted on 02 Mar 2024 12:30 PM
Re: Can't connect Sky Q to my eir broadband
i've the same issue as of today ,sky q wont connect to broadband
Message posted on 12 Mar 2024 07:34 PM
Any fix for this yet? Just replaced my Eir broadband with Eir Fibre and now Sky Q won't connect back to the broadband.
Message posted on 12 Mar 2024 08:40 PM
had to use a plug in wifi extender with an ethernet port. connected the extender to the wifi and plugged it in close to sky box, ran an ethernet cable from the extender to the sky box, issue sorted.
Message posted on 12 Mar 2024 09:19 PM
I unplugged the sky and my router. Left everything off for a few minutes and when I turned it all back on it was working fine.
Message posted on 13 Mar 2024 08:01 PM
Hey, thanks for the advice. That worked. I turned the sky box off for the night and turned the router off for a minute before I turned sky box back on. All connected fine now. Thanks a lot.
