Discussion topic: Lip sync issues changing from uhd to hd programmes
Re: Lip sync issues changing from uhd to hd programmes
Yeah I meant decoding the DD stream to output PCM
Avatar for 12345678M
This message was authored by: 12345678M
So I don't have a hdmi port on the sound bar just Bluetooth or optical .....
Ah! Ok new soundbar time 😉
can you still configure it as "passthrough" on the TV? Might make things worse or better.
Actually by turning everything to auto/normal and no Dolby it seems to be working mostly ok
will also look at soundbars,..
