3
This discussion topic has been answered Discussion topic: Landline & Sky TV
This message was authored by: 00Mandy44
Landline & Sky TV
I currently have a landline with BT which is not being used therefore will soon cancel. Will I still have Sky TV or do I need to do anything differently to set Sky up?
This message was authored by: DaveDrizen Answer
Re: Landline & Sky TV
Do you also have broadband from bt and will that go as well.? If so if  and have Sky Q which is Sky from satellite  you will receive you  normal live programming but how lose the use of the apps and I not sue if will effect on demand as sure ifcrpthat from the internet or you dish. If you are keeping broadband you  Sky will be ineffected, I don't have a land lie these days just broadband from bt and my Sky tv works as normal. In older days you Sky had to be connected to a land line but that situation changed.quite a few years ago and it just need to be connected to broadband instead. Thinking about that still may be a requirement.
Avatar for 00Mandy44
Thank you.
Yes, I will be keeping broadband. Therefore, will I need to do anything with Sky or just keep going as I am?
@00Mandy44 wrote:
Thank you.
Yes that corrects you do not have to do any thing as far you Sky set it will keep working as before. As I said I. no longer have land line just a mobile phone which the number is linked to my Sky account which is need if you want access your accont and two step verification is set up as Sky sends  a code to the mobile to put in to give you access  account or even access to this forum.
Answered - Go to Answer
