Discussion topic: Juddering balls in US Open tennis HD
This message was authored by: Q-tips
When watching Sky's HD tennis, the ball is constantly juddering/stuttering but the ball flight is smooth when I can watch in UHD. Is there a technical issue?
32B12C 2TB UHD Q box • Mini boxes x2 (32D0B2) • 2022 LG C2 OLED TV • Software vQ230.000.14.00L • Gigaclear gigabit FTTH broadband (935Mbps up/down) • Linksys Velop tri-band router; 3 mesh nodes • All Q boxes fully Cat6 hardwired • Q wi-fi disabled • Q picture/audio processing disabled (no sound bar) • Pixellation cured by Q170 but back again with Q190 and now every few minutes with Q210 and Q220 live broadcasts and recordings on all boxes
Re: Juddering balls in US Open tennis HD
the HD will be 1080i and need deinterlacing while the UHD one is full frame 4k and doesn't - maybe try changing your Q output to 1080i and see if the TV does it better?
Other possibility is bad framrate conversion from 60 to 50 but you'd think the UHD and HD versions would both be affected.
