Discussion topic: How to check satellite is on correct position of it has been knocked ?
Message posted on 02 Sep 2023 11:58 PM
My satellite dish has been knocked during building work and now saying no satellite signal is there a way I can see if it is aligned before getting an engineer out?
Message posted on 03 Sep 2023 06:18 AM
Re: How to check satellite is on correct position of it has been knocked ?
Not unless you have the correct equipment and know what you're doing. Take a look at the troubleshooting on the appropriate section of this link.
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
You will need to contact Sky and arrange for an engineer to check the alignment of your dish. Be aware that if you’re on a communal dish system you’ll have to contact your landlord or building management company rather than Sky.
