Discussion topic: Jez
This message was authored by: jezpfc
Jez
Daily for the last week I have had to reconnect one of the SkyQ mini boxes.
Now it will not reconnect at all and comes up with message.- MR004z
cannot just reactivate have to reset but now not working at all. The other box is fine
Re: Jez
Hi @jezpfc
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Avatar for jezpfc
Re: Jez
Thanks I have tried all that but now doesn't work
Re: Jez
What doesn't work now @jezpfc ?
Avatar for jezpfc
Re: Jez
The one of my mini boxes won't connect. Even when I have rebooted both the main unit and the mini box
Re: Jez
hi @jezpfc
Have you carried out a Network reset on the problem mini box?
Avatar for jezpfc
Re: Jez
I have although it worked for the first few days now doesn't reset
Re: Jez
What did you use for the WPS after a network reset @jezpfc ?
Avatar for jezpfc
Re: Jez
not sure what you mean by WPS
Re: Jez
Hi @jezpfc
Its what's required after carrying out a Network reset on a mini box all as explained in my first post
ie
Avatar for jezpfc
Re: Jez
Oh I have used the WPS button on the main box.
