Discussion topic: JVC smart tv
Message posted on 02 Apr 2023 07:39 PM
JVC smart tv
Recently purchased a JVC smart tv connected sky q box via hdmi lead to recognises the box on the source list, however video not supported message appears, have updated the tv software and tried other ports thanks
Message posted on 02 Apr 2023 07:41 PM - last edited: 02 Apr 2023 07:41 PM
Re: JVC smart tv
Hi @Flinty1982
Try pressing the following keys in sequence (when the SKY Q box is on)
Home 1 0 8 0 Home
Message posted on 02 Apr 2023 07:57 PM
Re: JVC smart tv
Thanks hasn't worked but many thanks for the reply
Message posted on 03 Apr 2023 01:34 AM - last edited: 03 Apr 2023 01:40 AM
Re: JVC smart tv
That message would normally be for an incoming resolution it can't display (and the Q after that remote button sequence should reset to bog standard 1080i). Tried another cable?
what model is it?
Message posted on 26 May 2023 04:56 PM
Re: JVC smart tv
Worked for me. Thanks so much
Message posted on 07 Sep 2024 02:38 PM
Re: JVC smart tv
Thanks so much. It also worked for me too
