4
This discussion topic has been answered Discussion topic: Itvx
This message was authored by: Wes11621
Itvx
I now have ITVX on my sky q box but I don't seem to have it on my extra boxes of which I have 3. Is this normal?
This message was authored by: PandJ2020 Answer
Re: Itvx
No, the app should be there too.
However, the app refresh may take a while.  If you have a voice remote for those boxes accessing it will make it appear.
Re: Itvx
Avatar for Wes11621
Re: Itvx
thanks I'll try that
This message was authored by: Luis+Suarez
Re: Itvx
That doesn't work.
Nor does using the engineers menu to refresh the apps.
4 mini boxes here, and none of them have the app. Only the main box has it.
Avatar for Wes11621
Re: Itvx
I found if your mini boxes are not updated to the  same software as the main sky q box  then some apps will be missing.
I updated the software so as they were all the same and the refreshed the apps on all the boxes and that worked.
